Shift linkage, A/T transmission floor shift
lonewolf73
9:40 AM
california
Hi all I was wandering if any1 knew where i can find the 1 linkage between the tranny an the the piece that goes through the floor Im tryin to change my column shift to a floor shifter.I have found the upper middle pieces along with the piece that goes on the tranny but to make it work i need the 1 missin rod. If any1 has it or knows where i can get 1 would be great.
Thanxs for the help
I just went through this myself, and I feel your pain. It seems like you're always finding one more part that you need.
I got all my pieces off ebay.
Ya thats where i found all but the 1 piece at is on ebay just got the upper rod linkage or waitin for the guy to sented it to me. theres the middle piece that goes through the floor an the piece that goes on the tranny i even found the column bushing an spring on there too.
with the above ? in mind i have a column shift linkage i was wandering if the 1 rod that i have now that hooks to the piece goin from the tranny to the subframe will that rod work ?
