azmopar4262
I bought a 72 satellite with a 318 about three years ago. Interior restored. All wiring restored. New battery, alternator, plugs, wires and the old points distributor changed to a new electronic one. The previous owner put a 4 barrel manifold and carb on it. It has always spit out black smoke and has no power. We obtained a 2 barrel manifold and 2 barrel carb from a savage yard. Manifold was cleaned and carb rebuilt.
The car still runs like crap. Black smoke and back firing. A friend tried to tune it and set timing, but still it isnt running right. Manual says the distributor has to point to cylinder one at top dead center, but it doesnt.
The distributor shaft does not fit into the gear inside the engine to allow the distrubutor to point to cylinder one. We cant turn the gear.
Can the gear be turned?
Has anyone else run into this with their 318?
Did someone monkey with the gear or camshaft?
Any help would be apprecitated.
Thanks John
Thanks John
