Ski 61701
- 5:58 AM
- Nov 21, 2016
- Bloomington Illinois
I had to narrow my hughes hold downs some more than others so the rocker tips would line up. So here starts the fun.....not but it will be correct when you're done. Look at your rockers now and see which ones are off center focus on those immediate hold downs a feeler gauge is your friend here. Some I barely dressed up with a belt sander, but I had to buy some .015 shims from them to get things correct. Its time consuming but you'll rest easier knowing your tips are centered on valve stem.
I dont use the springs, I use the aluminum spacers hughes sells, it will be a little easier to set clearances and centering rockers if you ditch the springs
Your scrub marks are going to be off due to inconsistency in rocker arm tip finish. I think back in the day people aren't so particular as we are now.
