FOUND Sill plate support Coronet -66
Mattias
5:59 PM
Sweden
Hi,
Looking for the sill plate support for passenger side (right side) for a Coronet 2dr HT -66. Also interested in the original screws, mostly to see what type they are.
Driver side (left side) in the picture.
Thanks
/Mattias
I have a support but I can’t be sure if the screws in my car are original for sure. I’m also not sure if the support came out of a Plymouth or Coronet. I would assume they are the same but sometimes Dodge did their own thing. I can get a picture and dimension of it for you today if interested but I don't think I’ll be able to get anything mailed until after Thanksgiving.
ohh, just noticed you are in Sweden. I have no idea what that shipping would involve.
Were these a 66 only part or did 67's also have sill plate supports?
I appreciate if you check what you have!
I have an address in US so you only have to think about shipping to Florida.
Thanks
OK - I’ll get a picture & measurement.
I have a pair of these but this is the better of the two. The other one has a bit of rust damage on the ends - nothin that affects function. They are 37-1/4” long. You can have the one for $10 + shipping or both for $15 and shipping. Also pictured is the screw mine are mounted with for info. I’m not 100% sure these are original but I suspect they are as they are a common fastener in Mopars of that year. They are also used for fastening the roof stainless channels that the upper window weatherstripping sits in.
View attachment 1561078View attachment 1561079
View attachment 1561080View attachment 1561081
Are they same or mirrored? Is the better one left or right?
As far as I can tell they are not side specific. The drilled hole pattern on one half is a mirror image of the hole pattern on the other end.
I will check the one I have and send you PM tomorrow afternoon.
Thank you!
