Garys1969RR
I recently got a 65 Belvedere that has the Eddy Performer RPM heads, headers, Holley Street Dominator Intake with a 3310 Holley carb, and a fairly mild cam. .480 lift, 280 duration. It also has 4.30 gears, and a full manual 727 T/Flite trans. Getting 210 to 220 PSI cranking compression. This thing will not break the tires loose in 1st gear! Just re built the distributor, new pick up and inductor wheel. That cured the higher RPM miss, but still weak on power output. Could a faulty coil cause this? I can swap the one off my RR to see if that helps. Bout ready to pull a head to check C/R, gasket thickness. I suppose a leakdown test would be a good place to continue the diagnosis. Sounds real healthy, good ex note and no smoke. Any ideas?
