JohnnyTak
Hello,
On my 69 Roadrunner 440 6bbl, I'm noticing a small backfire sound coming from the mufflers when in gear and the motor is just at or below 2000 rpm's. When I come to a red light, and I down shift through the gears above 2000 rpm's, there's no back fire sound until I approach the 2000 rpm mark or lower (small sound, not too loud). If I take it out of gear and coast in to the red light, no issues at all. There are not issues either when above 2000 rpm's either when down shifting. This started about a month ago. I wasn't sure what to do so I changed out spark plugs, and checked my distributor wires also. Does not seem to be an ignition problem. I did check my wires on the coil to make sure they were tight also. I did not check the distributor cap though. I have factory electronic ignition. On acceleration, the motor seems fine with no apparent missing. Not sure what to check next.
Car's exhaust system consists of TTi headers 1-3/4" with flowmaster 40's. I straight daul exhaust straight back to tail pipes. Mufflers were put on in 2008.
Thx,
Johnnytak
Thx,
Johnnytak
