Dreadl0ck
Just got the car shipped from florida to Sweden. It's been running 15 minutes at idle TOPS in the last year. It's a fresh build with less than 5000 miles on it according to the seller who's backed it with receipts and build sheets.
When car arrived it was pouring down outside so I backed into my garage and left it there with a battery charger since the *ss-hats had left the flashers on during the 8 week transportation.
Started the car to show a friend and it had a bit of smoke coming out of the engine around the headers which isn't anything unusual for a car that has been in storage for a while. No big deal. Started it up today and no smoke was seen until I shut it off - WTF? It's like a thin smoke coming out from the back side of the engine, drivers side and you can clearly hear a loud hissing sound for 2-4 seconds accompanied by the smoke.
Get worried as hell, asked a friend who thought it was a bit heavy smoke from the exhausts as well and got me worried about a blown gasket. So I need some advice here. I left it at idle to heat up a bit and there's no rapid pressure building up in the cooling system. Lower radiator hose is still soft and nice. Nu bubbling in the radiator - but coolant at a pretty low level. Noticed a small leak on the lower hose so I tightened that up and leak stopped. Still hissing noise and smoke when I turn it off.
It runs pretty good with good gas response when I idle it at around 2000 rpm. I was thinking the following
1) Drive the car around the neighborhood to burn off any residue left from storage and to let it breathe a bit
2) Check oil again - now it looks alright - no chocolate milkshake look.
3) Check coolant for bubbling or surging. Check coolant level after driving
4) Cylinder compression test
What gets me worried is that if I get coolant in the oil - things will go bad quickly during my test drive? Help please?
