solid cam
benno440
2:28 AM
australia
after reading last couple of posts regarding solid vs. hyd cam.
i have a question:
i currently have a hydraulic flat tappet cam with roller rockers.
what parts will i need to change to go to a solid?
*cam (of course)
*lifters
*pushrods
anything else?
and a solid roller tappet cam is that the one where it uses ball bearing type bearings instead of the conventional ones we use?
That should do it. I forgot to add.......if you go much bigger than your hydraulic cam you have now, you will need the matching valve springs for the solid cam. If it was mine, I would do it anyway.
