Solid street roller cam discussion
I seem to recall some discussion about this cam on another forum.
I thought in that discussion there was mention of it not being a billet core?
Perhaps I’m thinking of a different cam, but if it’s a cast core, I’d talk to Isky about a spring pressure recommendation.
If it’s a billet core, then disregard this post.
Yeah there were a few discussions about cams. That was a 408 Magnum I was building with a Comp hyd. roller.
Gus
Unless you're using a Dana 61 you're not going to get anything taller than a 3.54 ratio for a Dana 60.
I use Dana 61's, so I can take advantage of the taller 3.07 & 3.31 gear ratios.
Tom
Where have you found those ratios? We searched and never found any in stock.
Doug
Doug
Doug I have heard these ratios were used in early 80's Ford vans so I doubt you will find any new gear sets. I found some information on the Pirate 4X4 site.
I heard the same thing. Never found any.
Doug
Doug
I owned an 83 E250 with a 61 and 3.07s. I think cash for clunkers took a lot of that old iron away from wrecking yards.
