Speedo gear for 1964-65 chart
Ceedawg
12:51 AM
Va
Is there a chart for gear ratio teeth on the 64 trans, I have an 18 tooth, not sure what is was for, rear long gone so can’t check ratio. /6 3 speed manual trans.
Thanks
Can these still be bought?
i have a printed buried, i also have a selection of gears. 20 ans 21 teeth are the hardest to find.
How do they adjust from one size to another? The later is by turning the holder.
Thanks
Once you figure out what gear you need start a WTB add on here. More than likely a member will have one.
Good question. It might be the total height of the gear itself. All I know is you just install them and they work.
Some of the higher rear gear ratios do require an adapter.
Great, looks like I’ll need the adapter and 19-20-21 to start.big question, where does that adapter go? My cable is a solid rig right into trans unlike the later that screws on.
What? I didn't think they were changable due to not being able to adjust the distance from the tailshaft gear? I need a 17 tooth then... my speedo is like 80 at 40 right now..
