You're absolutely correct about the factory using high voltage welders. Most are also 3 phase units so they have a more consistent output due to the "sign" of the wavelength dropping up and down between cycles.............. but that's another "Johnny Kilowatt" story.
Your typical home is single phase.
I have been down this road............... I originally bought a cheap unit from Harbor Freight. I didn't use it for over a year and it sat brand new in the box.........
You see where this is going.
I finally used it to practice with and made a few spot welds using scrap sheet metal. It did "OK", then crapped out after about 20 welds were made. The switch failed. I took it back along with the box and receipt and explained to them about only using it for 20 or so welds. The tongs were still nice and shiny copper looking. The tips didn't even discolor too much from the heat that is generated during the welding............. I mean you could tell it was almost brand new.
They would NOT even consider offering a replacement unit. I didn't want a refund, just an exchange.
They told me that since I didn't purchase the "extended warranty" that I could pound sand you know where. This wouldn't have mattered anyhow since it was beyond a year.
So much for customer service.
I have not purchased anything from them since.............. not even a cheap bag of shop rags. They can kiss my @$$.
Next I went to the local Miller dealer and purchased this unit that has a timer to make sure the welds are consistent.
I had the cart, but by the time I purchased extra length tongs, and several bags of tips I had a little over $2K invested.
I have used it on several cars now and the welds look factory in appearance.
I did some practice welds first using scrap sheet metal of the same gauge thickness. Once I felt comfortable with it, and had the timer dialed in, I did some destructive testing, again on scrap sheet metal. I wanted to see how strong the welds were, and to make sure I had dialed in the correct time setting on the timer.
The metal tore around the weld............. the weld did not fail. This is the sign of a good spot weld.
As long as you have nice clean metal and no gaps, this will work great for a hobbyist. I will warn you that it gets very hot during use. You better use welding gloves !!!! I typically use mine for a while and let it cool off after a while. The unit is heavy, so you will want to take a break anyhow...... perfect time to let it cool off.
I would look for a similar "used" unit rather than waste your money at Harbor Freight.
This is a great home use welder. This one is a 220 Volt unit.
