Absolutely. Matter of fact just tied in the trans on Friday and made sure the plate was installed before setting the starter... Probably not going to have a castrophic failure if it's not there however; if you have it. Install it....Does any one use the thin spacer plate that goes between the starter and the bellhousing. In the past I just bolted it up to the bellhousing
Thanks Tom C
