716PKRT
Thanks steve340. Yeah I think yours is different. 1968 had the single terminal switch. In 1969 they went to the 3-prong switch, so maybe whatever the adjustment was, isn't applicable with the 3-prong switch. Mine is a 1972 and has the 3-prong switch. I can't find any adjustment procedure in the 1972 FSM. It does mention making sure the operating cam in the trans is centered in the opening for the switch. But it doesn't tell you anywhere I can find, what to do if it's not. Either the switch is bad or the cam is not hitting it correctly, you're right there. If there is an adjustment for the cam, I would guess I'd have to pull the pan and do it inside the trans. I'm not that experienced with automatics.
