Ok guys, now I am kind of stuck.
Today I went though the heads some. I did the "water test" and blew air into the ports to look for bubbles where the valves would be leaking. No leaks.
I also did the "flatness" test, using a old rigid metal ruler. There were a few spots where I was able to slip a .006" feeler gauge between it and the head surface, which means I will have to have them milled.
Ok, so I know the heads will be milled, and that's all they will need.
Now on to this hunk:
Feeling a little over my head. Any help would really be appreciated.
I was hoping since my compression was good, I would be able to just replace the head gaskets, and all the other gaskets while I had it out of the car, and call it a day.
Here is a look at the #1 cylinder.  It read 155psi on the compression test I took before yanking the heads. You can see the crosshatch hone and the ridge at the top of the cylinder is barely perceptible. You can't even catch you fingernail on it!!!!!
So with this piston I'm thinking I won't even touch the short block, other than checking the timing chain out and replacing some gaskets. Most of the other cylinders look good
BUT!
Then I noticed this on the #5 cylinder, and am totally confused about what it is and what it means. (Keep in mind that this cylinder had 130 psi on the compression test, with is REALLY good considering it had a cracked head gasket. I expect if the head gasket were attached it would be up there around 155+ like the other cylinders.)
I know it is hard to tell from pictures, but I will say that this mark could barely be felt by my fingers. Just barely if I closed my eyes, I could feel it. I can't tell if its coming in or out.
Guys, any thoughts???
Thank you!
