Hi Guys,
Need some help. Yesterday we started working on my Son's 73 Road Runner daily driver - the job was to remove and replace the steering gear.
We drove out the spring steel pin and have loosened the steering column. The problem is that I can't seem to pop the steering column (rag joint) off of the splined input to the steering gear. Again, the spring steel pin has been driven out, but it won't seem to budge.
Any suggestions for getting this thing loose would be appreciated!
Hawk
Here is a picture: Right off the splines where the rag joint(?) connects. You can see the pin is out, but these are the two pieces I can't seem to separate...
Hawk
