Steering wheel stucks in a certain position
Daniel Brunner
12:50 PM
Austria
Took my car on a test drive today and I realized when I turn far right at a certain position my wheel stops turning. Have to use a lot of strength to continue steering looks like something stuck inside? It’s making a knock noise when turned over.
I have a new steering box, turn signal switch and a stock steering wheel.
Wheel sits in right place
Can be the turn signal canceling ring in a wrong position?
Check the clearance between your idler arm,or pittman arm and the exhaust,especially if you have headers on the car.
worm gear, inside the box chipped or a broken tooth/vein (for lack of a better term)
chipped piece, moving around or getting in the way ?
best guess
Disconnect the drag link from the pitman arm... Then try it...If the binding/noise is still there it's in the box/column...
Chargervert's comment about clearance to the pitman arm is spot on, back in the 80's a guy I knew had a similar issue, when I looked for interference the car was lifted and nothing touched, but when sitting at ride height the tierod adjuster sleeve was turned in such a way the clamp scraped the header... If I hadn't noticed the shiny spot I could have easily missed the problem
