Yeah... I have the wilwood prop valve in the toolbox, and plan to eliminate the stock metering, just haven’t done that yet. Got curious about whether I “should” need a different MC size. Kinda ridiculous that wilwood told me to try and change to exactly the size that should already be in the car... and I told them i have the proportioning valve not-installed and they never even suggested to “well put that on”The drum master has a residual pressure valve built in that you should remove from the front brakes. That will not cause your problem however. The only valve that should be in your drum system is a pressure differential valve that turns on the dashboard light. If you installed a valve from a disc car it would have a metering valve that delays pressure to the front brakes. I would by pass what ever valve you have in there and install an adjustable prop valve in the rear line, and give it a try.
Don’t manual vs power brakes call for different bore sizes? Or is it strictly a pedal-ratio difference?The delay could also be the larger bore. I did a right stuff OE looking 15/16" and spliced in a prop valve to hold off the rears from locking up. Manual setup.
