pwtjr
Trying to make the best decision on a CLUTCH for my 69 Superbee. I have done the usual and Googled the subject. Also searched various forums. Alot of good information out there for sure, but was wanting to get some Mopar specific up to date opinions from the crowd on here.
My setup is pretty common: Mid 500 horse 440 with hydraulic roller cam, CNC'ed aluminum heads, 3 inch TTI exhaust, 3:55 gears... you get the picture. The cam is Comp's off the shelf 286HR, with duration of 236/242 @.050. Compression ratio is figured at 10.8:1. I am hoping for a really nice torque curve to make this heavy old B-Body alot of fun to drive around on the street, and hit the dragstrip 3 or 4 times a year.
My transmission is the 23 spline unit. I went through the transmission, and am now in the process of deciding which clutch to put in my car. With the internet research I have done, I have 3 options in mind:
My car will be driven 2-3 thousand miles per year. I realize the street manners of the real good sticky clutches require some getting used to. I am okay with that. I want my cake and eat it too, but understand I have to be realistic.
Any comments/help is appreciated.
- McCleod SuperStreet Pro - dual compound type disc with diaphragm plate
- McCleod RST - Twin Disc organic with diaphragm plate
- SPEC Stage 3+ - single disc carbon metallic with diaphragm plate
