One of the MAIN reasons why I started this thread titled:
Solid Rollers or Flat Tappet for street and strip. Looking for LONGEVITY and low maintenance...
https://www.forbbodiesonly.com/mopa...ing-for-longevity-and-low-maintenance.183713/
One of the main reasons for that inquiry is I am having Southeast Performance R/T in Tampa build out a BMP 541 cu in RB stroker for my 70 Roadrunner.
My understanding of
![:thumbsup: :thumbsup: :thumbsup:](/moparforum/styles/default/xenforo/smilies/ATT00014.gif)
Jim Laroy's
![Bowdown :lowdown: :lowdown:](/moparforum/styles/smilies/bowdown.gif)
advice and opinion on lifters for a performance build: NO to hydraulic roller lifters. "Lifter breakage and unreliable" is what my brain recalls as the summary.
@IQ52 please correct me or confirm, elaborate if you can. So in my wife's Pontiac 421 engine, although I went with a CompCams hydraulic roller cam and lifters per my local builder who did the work, and the cam specs, bore/stroke ratio and driving inclinations of my wife, small valve sizes, etc, and about a 5,600 RPM max shift point, I think they are going to be fine
for her engine...
But in my 541, I'm looking for 6XX HP and as close to 700 Ft Lbs torque, FAT, FLAT, and WIDE torque output. So hydraulic anything is out, although I would have been happy with hydraulic roller cam and lifters IF NOT for Jim's warning and concerns based on his experience, and that was all I needed to know. SO..that leaves SOLID (what)...?
Solid flat tappet or Solid roller?
Because I don't think my valve spring pressures are going to be "extreme" nor the grind or lift too "wild", I figure flat tappet solid lifters are ideal, solid rollers being dismissed because of "oil starvation in stop and go traffic" of which I WILL see a LOT of. The other concern I have is more maintenance with rollers, having to rebuild them, although the number of miles between rebuilds would be a factor, oil starvation in stop and go traffic is a non starter.
So that points me to solid flat tappet cam and lifters, and I will remind you all that the larger diameter of the MOPAR/AMC lifters gives us the ability to make use of a more aggressive "roller-like" cam lobe profile.
