Check for taper of the crush on old gasket. See if it's thicker near the bottom of ports.
Heads did not need resurfacing, but since the intake is a true factory crossram it would not suprise me to find an issue thereCheck the manifold fit without a gasket if you get that far. Maybe a regular 4 bll intake so you can see if there's a gap at the bottom of the runners. Having head work done, did they resurface them any that might have changed the fit? Block resurfacing will change the perfect fit of the intake also.
Good luck.
No obvious signs of intake gasket failure, no signs of oil on intake valves ....
So, are you pretty sure that is the cause of your oil loss?A closer look shows that I don't seem to be getting enough clamping force acoss the lower part of each intake port.
Honestly no I am not sure. I would think if oil was being pulled past intake valve on #6 cylinder that was fouled that I would see oil on the back side of the valve but I don't see anything wet with oil there on any cylinders.So, are you pretty sure that is the cause of your oil loss?
One of my favorite cams.509 cam
A milled block or the intake could have been milled at one time.So what might cause an incorrect mating angle between the heads and the intake and how can I check that?
To add to this use a feeler gauge around the edges, you should have equal contact all around.... Quite likely you don't... And correcting that means milling but then the intake sinks so next your milling the heads and/or block... Tough to get it 100% right....A milled block or the intake could have been milled at one time.
To check, have the heads and intake clean and set the intake on without a gasket. Check the gap. Look for how true it mates to the heads.
Already mentioned, look at the old gaskets to see if they were compressed more at the top compared to the bottom half.
I agree especially with wedge intake bolts going on the inside LOL. They are a pain to install and removeI don’t know if they used washers from the factory or not, but it sure seems like using them is an invitation for dropping something down into the manifold.
