P Dubya
I haven't been this aggravated in quite a while.... I'm now 2 Sunday afternoons into this no spark problem and made no progress. From everything I can see it looks like I'm not getting the step up in voltage while I crank the engine over. With the key on I have about 3.5 volts on the + terminal of the coil (seems low but thats what I have, maybe that is enough to run after starting?) Negative terminal shows about 1.5 volts. While cranking the voltage never jumps up enough to light up a test light (incandescent bulb). Air gap at the reluctor/pickup coil is .008''. Orange ECU/transistor box is well grounded to both the firewall and I also added a dedicated ground wire to the intake for assurance. Ceramic resistor is fed at the top 2 spades by two blue ( I think) wires. Bottom 2 spades have 3 wires connected which I presume feed the coil. One of them is blue and is connected to the + terminal. Tested for continuity and seems to be fine. What am I missing?
