moparist
I'm working on my 65 Coronet with an 8.75 rear axle. I have two pumpkins for it. One is a 741 w/3.23 gears and a clutch-type sure grip. The other is a fresh-built 489 case w/3.55 gears and an Auburn-type posi unit, fresh from Randy's R & P. Back in the day, you could go and buy generic "Posi fluid". Now you need to buy the 80-90 gear oil and put in some additive. I went to the local Car Quest and they have the gear oil and additive. The parts guy also said he has 80-90 synthetic oil with the additive already in it. What do I need to put in the rear end (Coronet's) to make each/both work as advertised??? I'm so confused
