Griff
I'm just now putting in my aftermarket SW gauge cluster in my 69 Roadrunner. All is wired up correctly and I had a friend double check as well. When I start the car, oil pressure gage pegs at 100psi. I know the car runs at a steady 33psi on a good mechanical gage that is made just for checking oil pressure, (not for mounting in a car). I had that gage zip tied to the cowl for the winter while I was breaking in motor and running engine over the last few months.
Sending unit, (which is an after market "bell" shaped electric gauge, that is not SW branded), but bought new from Mancini. With car running, I can take sending unit wire off, gauge drops to zero. Then, I can ground that wire to block it again pegs to 100. Repeated this a few times, same results.
I checked to make sure sending unit wasn't grounding itself to block (72 - 440).
Any help would be appreciated.
Thank you
PS - The gauge cluster was bought used and I was assured all worked. Temp and alt gauges work perfect.
Thank you
