pb24
I have a 68 charger with power drum brakes. I have the spindles and brake caliper adapters from a 73+ A body. My car has the factory front sway bar and I've read if you mount the calipers forward facing they will hit the sway bar or you can swap the left and right spindle and mount the calipers toward the rear to alleviate this problem. If you do mount them toward the rear what brake hoses do you use and how do you route them. I've read the Mopar Action article Disc-o-Tech and they recommend not doing it. Has anyone done this modification and do you have any picture
