I'm not clear on what's going on at this point.
As I understand it.
The tach works OK now other than not giving steady indication when the engine is running and the needle points to the radio speaker when turned off.
Wait let me go to the garage and look..........
I think the needle pointing to the radio when off is NOT a problem based on my operating characteristics. Functionality is good, in my case after providing a ground. Maybe that's "normal".
If your needle is shaking during operation after you provided a ground?
Other than a possible ignition signal problem causing an unsteady induction, one difference in our cars COULD be your radio. Note previously that I've had mine updated. Certainly not a problem if the radio isn't even on??
