Cranking it just fills the carb up. Pumping it once set's the choke and gives it a squirt of gas to start it. If the carb is full and the choke adjustment is correct, only one pump is needed.
Ethanol fuel today is not what gasoline was back in the 60's, and 70's. Ethanol mixed gas tends to evaporate quickly. Fuel injected cars don't have a problem because of high pressure fuel pumps, as opposed to the older mechanical fuel pumps. A carb spacer prevents heat soak in the carb.That doesn't sound right.
What doesn't sound right ?That doesn't sound right.
I thought you said ethanol will not gum up your fuel system. That is wrong.What doesn't sound right ?
Ethanol based fuel gunks up your fuel system and causes rust in the gas tank. Believe me, I know. I just replaced the tanks in both my old
If it sits for a long time, yes it will. It's not as bad as the old for gas that was produced in the 60's, and 70's. That stuff went bad in a hurry.I thought you said ethanol will not gum up your fuel system. That is wrong.
I agree. especially if the engine has a flat tappet cam.Veeeeeeeery bad for an engine to be cranked to be cranked for a long period without oil circulating.
that was Demon carb before EFI with mechanical pump on your car?4x to the floor.
