I sent my eBay core cluster to Bob's speedometer, got the amp gauge sodderd, Speedo got rebuilt, replaced the volt limiter.... I went with a 2 1/8" volt meter and made it fit the dash... got some ebay vent ducts and grille centersection to play with. Going to ebay for cheap junk to familiarize and to experiment with the cluster came modified for an 8 track player and I just got my player back from Barry's 8 track center... my disc brake proportion valve is mounted around the fuse block neer the e brake release lever.... I have taken about 3month's working out the dash. I'm going to use headlight relays... accessory relays and electric choke. A powermaster alternator with a suppressor a 8ga bypass to the battery another suppressor and 8 ga wire to a Rockford fosgate punch 150 that's been sent out to amp repair center the rear deck has 3 6x9 speaker holes factory and I'm going to convert the single front 4x10" speaker to 6x9 and use 4 61/2" speakers in the doors there plyle gear and it has a design that looks like the mopar triangle... it may be over kill but it's what I want.... I have read all I can find on electrical on the various mopar boards... I can put it all back to stock if I want later... I plan to make new door cards from plywood and my old seat covers when I get that far....
