YoungMopar
- 7:47 PM
- Aug 26, 2013
- Manchester, new Hampshire
so i have a stethoscope that i used to listen around the motor while it was running and the chattering is coming from the bellhousing. well i can say that when i pulled the motor there were marks in the housing directly below and above the flywheel. i grabbed the input shaft and tried to see if it budges and i really couldnt move it, but im thinking the chattering is from the torque converter bouncing up and down. so my question is... where can i find an input shaft bearing for a 727 searching the web and found nothing. any ideas?!
