john.thompson068
So my car has always run a little hot, even with a fan shroud, 18" MP viscous fan, and 19x26 4 core aluminum radiator. Like 210-220 degrees in traffic, and even once to 230*. But while cruising it stays at around 160-180*. I am in the process of installing two 10" 1100 cfm Zirgo fans in front. In the process I had to remove the viscous fan and radiator. The MP viscous fan seems like it has really small blades, and there is only five blades with large gaps between the blades. When looking at the fan off the motor it was no wonder that a 550 hp 440 motor would run hot. I am not going to want to put this fan back in. I think it is inadequate, and possibly designed only for a factory type 440 motor. I don't totally have faith in the viscous clutch either. It seems weird that I can make the fan move independent of the pulley. I have tested the clutch, and apparently it is doing what it is supposed to do. The MP viscous fan also sits within a half inch of my radiator, and I don't know if that is too close to work right or what. I am thinking of going with this Flex a lite fan. I can call Flex a lite to see how the far the fan should be from the radiator then I can buy whatever space I need. The Flex a lite seems like it would pull more cfm just by looking at it. And because the fan blades straighten out at high rpm it would be like the fan was no longer there. Here is a link to the new fan I am thinking about trying.
http://www.summitracing.com/parts/FLX-1318/
These fans are $40 and a spacer is $15.
