I'd lay money that you have a Satellite Sebring hard top (REH23) that has had a Roar Runner (RM21) hood, driver's door, and rallye cluster swapped in.
If the tile matches the dash, and the body VIN locations (the radiator core support, and the cowl), for the RH23 car, you're good.
If the dash from the RR has been swapped in, you can still, logically be OK, and it could be rectified as easy as getting a reproduction VIN tag.
If the title is for the RR and the dash including the VIN has been swapped, that's a different story and will likely depend on your ethical views on a "body swap".
