chevygirl812
New Member
Just curious, but what would you offer to pay for one of these carbs?Looks bad ***. I would try it, but not for 1200.
I just happened to stumble across one of these carbs and i have been search all over the net trying to figure it out. Just curious as to what you would consider a good deal for one would be?You would laugh if I told you what I imagined before when people discussed 3 BBL carbs before this thread ha ha! Or actually I'm sure you have a pretty good idea !!
Imagine 3 tubes LOL.
I would love to have one of these things now although I doubt I ever will unless I stumble upon a good deal or pick one up in a car purchase or something.
well, i haven't been able to dig far enough into al the numbers on it but from what i have found so far it is a 1030 or 1050Well I'm a cheap ***,but if it was rebuilt and depending on the cfm... $550.
Are you actually wanting to buy one?I just happened to stumble across one of these carbs and i have been search all over the net trying to figure it out. Just curious as to what you would consider a good deal for one would be?
No, I am not looking to buy one. I have one that I would like to sell. The date code on it is 951 and from what I have been able to find out is that it was made the first week of May in 1969.Are you actually wanting to buy one?
You can see and figure out the date code but didn't see the list number that ID's the carb? Both numbers are usually in the same place on the air horn.
Yes I have the list code it is a 4604S. The problem is with the websites that I have came across while researching this carb, they have conflicting cfm's some say 1030 and some say 1050.You can see and figure out the date code but didn't see the list number that ID's the carb? Both numbers are usually in the same place on the air horn.
Thank you for having my back on that one. I got a little heated over Meep-Meep's comment. I hear dumb things like that all the time since I am a female.The 3916 and 4604 do not have an air horn,the list number it stamped on the top of the main body on driver side.
Rebuild kits available for the 3bbl. Carter?
Carter made less than 25 3636S three barrels,doubt you will ever find one,original application was 63 Pontiac Super Duty.
