Throttle cable
64Belvedere
2:52 PM
PEI Canada
I am putting a Holley Double pumper on my 64 Belv with a big block and I can't seem to adjust the throttle cable to allow me WOT. When the pedal inside hits the floor I'm at about 2/3 on the carb...It is the original pedal setup and cable. Any advice?
Use a /6 cable,Raise the bracket up for a straighter pull.
i had the same problem with mine. i found that the cable was to straight, you actually get more pull when the cable is at an angle. i have my cable mounted about a 1/2 inch lower than the pivot ball on the carb....
i found my problem was inside the car, the pedal rod with the wheel needed to be pulled up and readjusted upward l.
i guess after years of depressing the pedal, it flattened out a touch.now i get WOT!!
I'm picing up the Mopar linkage adapter for the Carb on Monday. That should help me some. I may have to adjust the pedal inside after that.
