hangn0ut
Not long ago someone was marketing a bearing to replace that bushing.
Unfortunately he said he can't. He doesn't have access to any shim material with a .485 id. That is what I am hoping someone can point me to.Your machinist can make it,very easily.
roller cam endplay, (or thrust) .008- .010I know where your going and well,you dont really need it. What you will be doing is checking on that gear. Cause sometimes they last and sometimes they dont.
Thanks for the source! You would wouldn't by chance have a part number would you? I am poking around their site but they have a LOT of stuff to wade through. Just when I think I might be on the right track I come up emptyMcMaster Carr has them. I usually run a .005" shim under them.
minus the lash, sounds like it`ll work.Bushings already came today. Almost as fast as Amazon. So I started taking things down today. Amazingly nothing fought me so far. Old heads are off, gasket surfaces are cleaned. Oil pump and fuel pump are off and gaskets cleaned. Timing chain and cover comes off tomorrow and the cam goes in. I'm nervous about piston to valve and spring clearances. Cam is .701 net lift on the intake. Trick flow springs are supposedly good to .700 so I might need different springs. I'll find out when checking things.
Unfortunately that is minus the lash. Gross lift came out to .715 and the lash is .014 on the intake and .016 on the exhaust. It was supposed to be .700 gross but apparently there was a miscommunication. Hopefully there is a little fudge factor left in the springs.minus the lash, sounds like it`ll work.
Will do. Thanks for that, it's a good tip.Check the coil bind. Don't forget to account for the step on the retainer when checking the inner spring.
