EngineerDoug
Hello all,
I am in the throes of tearing apart - and deciding what to fix - on my '68 383 2BBL. I am the guy who has been asking about main bearings and what not. After going through the bottom end, I decided I had better pull the heads and have a look-see. The engine was running OK before I tore it apart, and the compression test results were decent, with acceptable variation between the cylinders.
So now I have the heads off (906 heads), and the bores are scary worn. No scratches or gouges, but a lot of ridge at the top of the cylinders. I am about to mike the bores, but I'd say those ridges are at least 10 thou deep. So I may go against my vow to NOT put much money into this motor, and bore/hone it for new slugs and rings. I have to remove the pistons to properly clean the block anyway, given the carbon and sludge that was circulating in this engine.
Here's my question of the day - I don't know which head gaskets I will use yet, but I am looking at the water passages that go from the block into the head. There are three that sit up near the valley side and pass through the 'V' between the cylinders. The passages are maybe the size of a dime. I see that these are clogged with who-knows-what. Looking at photos of both the steel shim and composition head gaskets, I see there are only narrow slots in this area. My stock gaskets had much larger openings - can anybody shed light on this? Why such a small opening?
