Ironbuilt
Spent a lot of time fighting with your fellow millwrights over whose job something was on a jobsite. 16 years in the Union, and the lines are still blurred to me.As a union millwright
As an Ironworker, I installed steel "man doors". I did the frames, the doors and the closures. However, I was not allowed to install the knobs. That was the millwrights job. Why? I have no idea.I know clearly what you speak about.
I started in 1976 as an apprentice in my chosen trade. -On my first job, I learned about internal fighting about "jurisdiction"(with pipe fitters).
Many stories of jurisdictional conflicts --are under my belt--- with the Ironworkers Union. (most were ugly and counterproductive for all involved)
For the last 25 years of my working, I have been a GF on every job. Some with only me and some with 30 working for me.
So I can easily say that --I have been there and done that.
Since this is a thread about tools--
I also was on the executive board of my local union for 18 years (unpaid position).
I personally have given myself as being a --"tool" to build what we have to date.
I guess because he was the "key" man on the job site Iron...![]()
When we all worked together, things got done a lot faster.You ask a question that has no realistic (or practical) answer. This gets into the guts of what our "negotiators" do/did to gain power and control for their little cozy.
Hate the other guy (union) and take what can be taken.--An age-old fight--
The -stupid- bottom line is --all of us (on any project) are working for a common goal.
I am strongly resisting the temptation to draw parallels to current political issues. But I see it to --all be the same basic conflict.--A quest for power and influence.--Simple sandbox kicking stuff--
I have. The "right way" works just as well as the "wrong way". It is a versital tool.Ever consider there is a right way , and a wrong way to putting an adjustable wrench on a nut? ..................MO
Yea, they round the nut off equally both ways.I have. The "right way" works just as well as the "wrong way". It is a versital tool.
Thanks Ws, I didn't spend the entire 18 minutes watching the ways in which a MSW can fail, especially with a cheater but I get the jist.
I would rather grab a real wrench. A MSW has it's uses as any tool does but breaking loose tough stubborn nuts ain't one of them. If a nut has shrunk I would rather try a metric socket or wrench or drive a socket that is a bit too small over it then hit it with an impact. If that fails chisel. If that fails cut off wheel. If that fails, torch.
Breaking stubborn stuff loose is the funnest part of this game.
That is what most people think..........MOI have. The "right way" works just as well as the "wrong way". It is a versital tool.
Sometimes a nut/bolt will "round off" because they are either soft or stuck to the point that they are toast anyway.
Also when a bolt or nut has rusted- it tends to get smaller on the flats and reduce the close fit needed for a dedicated wrench size to fit as intended.
An adjustable wrench can make up that difference from original size vs actual size.
I found this video and was surprised at how well it would fit in this thread.-(wrenching issue)
Tools are just that. They work or fail. Blaming a tool for a problem is silly.I thought I had saved pictures of the tools we destroyed trying to get the original pitman arm off of my son's 72 Duster but I can't find them.
900 foot pounds of torque can raise hell on things. Lots 'o shrapnel flying in the shop that day but we eventually won.
