Cornpatch MO
I did this to get a trunk open. took out rear seat and used extensions to take the trunk latch apart from the inside............................MO
It is for that application, I wish I had short sockets with the U joint attached. The joints that flop around really aggravate me..............................MOUsed that approach with 727 to block bolts. had a U joint in there too. Forget which car it was on.
I tape the flex joint with electrical tape. It still flexes, but doesn't flop all over. I've also used heat shrink wrap, but doesn't last as long.As I recall it did take a lot of patience to get the socket on the bolt due to the U joint flop.
Paper in the socket to hold the bolt in place also worksI tape the flex joint with electrical tape. It still flexes, but doesn't flop all over. I've also used heat shrink wrap, but doesn't last as long.![]()
It is for that application, I wish I had short sockets with the U joint attached. The joints that flop around really aggravate me..............................MO[/QUOTE
I have some tic tac sized rare earth magnets, tape a couple to outside of a socket to hold bolt.
Can't beat the u-joints. Must have in every tool box.Used that approach with 727 to block bolts. had a U joint in there too. Forget which car it was on.
Chekov certainly went through a lot of work to save himself a few hundred bucks.
Spoken like a man man who doesn't even know how to use a ******* hammer.Chekov certainly went through a lot of work to save himself a few hundred bucks.
