shone190
Hi guys,
I read so many articles regarding torque converter stall speed but I still have some concerns.
My main question is, what is the difference between, for the example, 1200rmp and 2800rpm stall speed converters?
As I understood, first converter will be fully engaged after 1200rpm, and the other after 2800rpm. So, if I never have a need to race with the car with left foot on brake pedal and right on the gas pedal, I will only see difference in fuel consumption between two of them?
Also, if I started from stop light "normally" with using only right foot (depress brake pedal and press gas pedal), the car will be quicker with 1200rpm stall converter because it will be sooner fully engaged?
Am I right or I missed something?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks to all in advance.
