i just replaced the t/c on my 360/727 heavy duty tranny that was in my truck.the old one had about 6-8 teeth missing.can it be repaired by welding a new teeth ring on it or is it just an ornament now.
You have to see if a replacement "ring" is available first, if yes, then you could replace it. I have replaced ones that weren't welded on. Just heat them up with a torch and they fall off. Heat up the new one and drop it on. (Manual trans that is) T/C, probably not...
