if your referring to the carb mounting screws 5lftlbs would work. sometimes i just tighten them by hand with a nut driver.. keep in mind the aluminum is easy to mess up.
Thank you gentlemen. The aluminum intake was my cause for concern; and I will be conservative with the torque, crank it, and then see if the carb-to-intake bolts needs further tightening.
After tightening, double check the secondary throttle plates move freely and there's no sticking through the movement. Its scary as hell when they stick open momentarily. Ask me how I know.
