Another reason it needs less torque is because the bolts will be tighter when it gets hotter as aluminium expands more than steel when hot. Twice as much in fact....depending on grade of iron (steel is the same) or the mix of the aluminum, the coefficient of linear expansion is around 2.4 for aluminum and just 1.2 for steel/iron.
