Bars measure .900 so they are the correct ones. I did see that the upper a arms are nearly against the bump stops with the suspension loaded.
Except for the bars being on the wrong side, the adjusters still shouldn't be hitting the frame....Have you checked to make sure the bars are actually installed on the correct side of the car? Left is not on right and vice versa?
Every tension a torsion bar in the wrong direction?Have you checked to make sure the bars are actually installed on the correct side of the car? Left is not on right and vice versa?
Beekeepers has photos attached at beginning of thread. I have never seen this before Cranky.Didn't read all the replies but it shouldn't matter how wasted the bars are, nothing should be rubbing against the adjusters. I've run plenty of cars with the front end way up to cars on the ground and nothing should be touching the adjusters all through the suspension travel no matter if the stops are gone.....
If everything looks to be in order that would be a good place to start.maybe the bars are not clocked correctly in the lower control arms?
