50 Coupe
What are y'all's experiences using hose vs. Hard lines for trans to cooler/ radiator? What about hose to hard line at the fittings?
Thanks.
Thanks.
Ok, thanks for the lead dvw!I use both. Factory style stuff I use steel. Stuff that going yp come apart often like the racecar gets braided. I just used this hose. I've used ther fittings on other stuff. Worked well. The only things other you would need are two 1/8npt to -6 male/male fittings and a cooler with -6 ends.
Doug
Amazon.com
