Gospel Runner
I have a 70 RoadRunner I am putting in a stoker 440 and changing from a 4 speed to a 727 transmission. I am using an engine plate to secure the engine in place of the regular mounts and a mid-plate. I currently have the engine and transmission in the car without the mid-plate and there are several problems. The engine is at least two inches forward from its normal resting place. I was instructed to put the transmission in first then mark where the engine rests and go from there. The engine is hitting the K-member mount on the drivers side because of the block plug on that side is too far forward. The engine plate is sitting on the frame ledge on the driver side, but not on the passenger side. There is plenty room for it to center istself and rest properly, if I could move the engine back. I am using the indy external oiling system and the external braided hose is blocked by the K-member. I am also using TTI headers and can't see how they will fit in this tiny space that I am looking at. As you can see, I am in what seems to be a mess.
Question # 1. Am I using the correct transmission mount? The same one from the 4 speed, that I was told I could use. It is my guess that if I can correct this problem, I will have the solution to the 2" I need to move this engine back.
Question # 2. Does anyone have pics of their similar set-up that I can see in detail?
Question # 3. How can I route the external oiling hose to work around the K-member?
Question # 4. Is this a bad joke, or how will I get my $800.00 TTI's into this space? Yes I have power steering!
