zdillinger
Guys, does anyone know how the wiring for the trunk light was run on a '73 Satellite? I have a green wire from the harness that should go to it, but some jackwagon cut it off and spliced in a red wire, then zip-tied it to the deck lid hinge. That red wire is cut off and just hanging now, but I'd like to hook up the trunk light again, assuming the mercury switch in the light still works...
Also, can anyone tell me if the map light is supposed to only work when the dome light is on? It seems like I should be able to turn the map light on whether or not the door is open, or whether the interior dimmer switch is turned on to allow the dome. Is this right or is something messed up?
