uwss
I purchased the 2" TTI headers for my 69 Plymouth GTX. I like the headers but you do have to some modifications for the headers to fit.
1. I have head studs; the bottom of the header flange will have to be trimmed so the head studs will clear. There are 4 studs that will interfere on both the passenger and driver side;
2. On the passenger side the last bolt on the engine to bell housing will need to be reversed so the head of the bolt is facing front and the nut is facing the rear; the headers will hit this bolt and will not allow the headers to rotate so the flange mates up properly to head;
3. I am using flat out copper header gaskets;
4. I am getting rid of the Hooker headers because I keep blowing no.5 exhaust gasket; yes i keep tightening the bolts but the bolts keep loosening;
5. I am going to try the stage 8 bolts with the locking tab.
The old exhaust is 2 1/4 and I am going to go with 3" exhaust which should be in tomorrow. I look forward to seeing how this new TTI exhaust system will help the performance of the newly rebuilt 440 which is now 520 cu in. ; 4 speed, 4:10 rear end.
