Turbine Bronze 67 GTX HEMI 4 Speed
Starting to make progress. However ran into some challenges.
These heater core inlets don't look right after getting the heater box in. Not sure if I did something wrong or what but I imagine they are supposed to stick out evenly and further.
The aftermarket replacement heater cores have shorter tubes that barely protrude through the firewall... Yours look better than mine did... Mine both tubes had less than 1/2" protruding.... I found the tubes are exactly the same size as 1/2" household plumbing copper so I cut the tubes right even with the fiberglass heater box & spliced in 1" of pipe.... four slip couplers, a couple inches of copper pipe & fifteen minutes soldering now the nipples stick out like they should...
