Not really necessary at that performance level on a BB Mopar... Can you tune a boosted engine ??, Do you have the knowledge to build a boosted engine ??, Do you know the cause & effect of doing a boosted engine of any kind ??, if NOT, I would highly suggest buying a couple books on the subject of Supercharging or Turbocharging & seriously do some due diligence & research, on all the aspects of a boosted engine, not just the cool factor or HP.... A naturally aspirated non-boost mild Mopar BB in B or RB engine can make 450-500hp/tq very easily, even a decent 360 can do it easily & have great street manners... IMHFO it's all about the heads, especially on a BB Mopar, then the induction/fuel system, exhaust, ignition, gears trans, etc., then getting traction.... The turbo & centrifugal {even a roots or screw type} superchargers are great, if you have the proper knowledge & wallet to build & use them.... The proper style rings, block prep {even the type gaskets used}, hardware also, like installing ARP studded everything, not just cheapo basic/stock head or main bolts, you will be asking for trouble on a performance based boosted combo... A Block girdle will be a great idea also.... There is far more to it than just bolting on a boost parts, like a Turbo or Centrifugal air pump or a special mount or manifold... It's still all about heads {porting if you want to get the most out of any combo, even a boosted combo}, valves sizes, special camshaft designed for a using a supercharger or turbocharger, the under hood room & an adequate mounting area {along with the added under-hood heat}, valve train, cooling {water & air/induction}, fuel system, carb or TB or port Injection, then size & style of exhaust, gear selection, trans type, boost relief for when you let off, so you don't get a big dose of boost pressure, in the intake manifold, then maybe also boost retard, for the ignition under a higher boost load & for a higher boost level, maybe methanol injection too, then there's waste-gate pop off or relief valve, or what ever else is needed, are all equally as important, especially when dealing with an engine, with boost of any type... Then there's the issue of room or will it fit under the hood etc.... Cast pistons & crankshaft, can & will work, but are by far inferior to the Forged & Steel alternative... better to be safe & not sorry, spend a little more now save allot latter.... well maybe anyway...LOL... a few things to think about
