Turn signal
marlabuck
11:05 PM
Long Beach,Wa
:eek:...so,the right turn signal dash light is working fine,but the left will not work...the front and back turn signals work fine both left and right but the left dash indicator does not flash, when I turn the hazard lights on only the right side flashes but again both front and back lights work...hummm...any thoughts? Marla
Replace the dash bulb?
Thanks for getting back to me so fast...I felt around under the dash where the bulb should be but was unclear that there was even bulbs I thought maybe the printed circuit board was in some way involved...so there is a bulb in there...I'll try to pull it out...don't need to remove the dash cluster to do this I hope. Marla
No need to remove the cluster Marla.....Unless you really want to. Then we'll just refer to you as "CrazyMarla"
I have been known to get a bit wild and crazy...LOL Marla
sorry marla,,,im sitting here snikkering..... this is tooooo funny ! T-H-E- B-U-L-B I-S B-U-R-N-E-D- -O-U-T S-W-E-E-T-Y
Marla, don't take the cluster out, like they say. But have your hubby take pictures while you change it, in case any of the rest of us ever have to do it. I'll thank your better half in advanced.
Yes it was the bulb...hanging upside down under the dash probably would have made a good photo...should of thought of it...actually it went very smoothly...pop out...change the 57...pop back in...DUH!!!...can I say that I had a blond moment?...Marla
