Is the spark plug firing order molded on the intake manifold?
			Yeah the order on the cap is right but right now the #1 wire is pointing to about 10 oclock. It was near 6/7 before i started to retard the timing. Ill have to straighten that out tomorrow.
	ugh, morning peeps! :coffee2: Here's hoping the car gnomes came in the middle of the night and fixed the car.
But anyways, Otherguy, do you have an eaiser way for him to check and make sure that the rotor is in the #1 position when it needs to be for the #1 cylinder? If the rotor is out of position, that would cause the backfire up through the carb right? I wonder if the choke plate is open or closed when he's starting it?
Haha think of the next thing that I'm supposed to test.
I like that method!!! Much better than trying to listen for air exhaling from the spark plug hole. Way more easier!!!
well, that method is more helpful on a gm engine(not sure how BB mopars are setup), because you can drop the distributor in them at any position..s/b mopars are just so easy with the flat keyed positioner on the distributor shaft...Again, as long as cam timing wasn't touched, you can only be 180* out, or right on...
DOH!! My bad, assumed it was a big block car.
He needs to slow down while doing his trouble shooting. Personally, I would have checked the battery volts first to see what that was. Once I knew whether the battery volts were good or not, then I would have moved to turning the dizzy 180 degrees. Its been beat into me to make one change at a time.
Well I'm not sure what I could have done wrong installing the heads. They were professionally done so all I had to do was torque then down correctly. I didn't turn the engine over at all so the cam shouldn't have moved. Ill recheck my firing order and if that doesn't fix it then illbypass that brown wire. And ill look at that wiring diagram and quadruple check that every wire is in the right place. Could this be an issue with my electric choke?
Well, i usually check for tdc the old skool way by removing the #1 plug, then sticking a wadded up piece of paper towel in the spark plug hole, remove the distributor cap so i can see the rotor position..then i bump the engine over until the piece of paper towel pops out of the spark plug hole...you need to do very short/quick bumps on the starter relay, otherwise you will go past tdc...anyhow lol...when the piece of paper towel pops out, the rotor button should be pointing at or very close to the #1 spark plug position, which is about 6:30/7:00 o'clock..it will also pop out 180* from the #1 plug position, either way you found tdc, just one will be on the intake stroke, and one on the exhaust stroke...
 It looks like its 180* from #1. And this is the only position it would pop out at. It didnt pop out 180* across any of the 3 times.
