Universal joints.....
Are the cups on the u-joint with red seals seated? If you put that in a vise and gently tighten it do the cups move in so clip to clip measure 2.125"?
Is it possible this needs some type of conversion u-joint? There are three types of them I think.
No sir, the yolks are the same size. I might just have to take it to a drive shaft shop
So this is interesting. All the U joints that I have gotten that say they are 2.125 ...are not. I have yet to get a true 2.125 7620 joint. Anyone have one? I'm taking this part back to Summit, but I also want to confirm this with them in person so they can see it. Moog 246 U Joints are not true 2.125 out of the box.
Went to summit racing and there different u joints.....all were incorrect. Is there some magic u joint that came out for a 67 coronet?
I'm going to try these.
NEAPCO 1-6300
That's a 7260 u-joint that comes on small blocks not about B or RBs.
There are only 3 Mopar factory joints. 7260, 7290, and 1330. If one of those doesn’t fit the installation process is incorrect or the inner width of the driveshaft has been bent slightly. I would get someone with real world U joint experience to help you. By the way. Buy a real dial caliper, they’re cheap.
Make sure you get it right
not just okay or it will work
This is the result of U-joint failure
it happened while on the dyno
And it's going to cost me a bit
but I will never use anything but Spicer again
Also going with the largest size U-joint
IMG_20201012_155349930.jpg IMG_20201012_172613689_HDR.jpg IMG_20201012_172632093_HDR.jpg
I'm going through EXACTLY what you did with the u joints.
Everyone claims 2.125 (2 1/8") but is actually about a 1/4" (2 3/8") too wide.
I tried Spicer, Napa, Duralast, all claiming 2.125, but all too wide.
Can I press them in with my 25 ton press? Yes but they are too tight.
I was hoping to mix and match new and old, but the cap inner diameter is different.
I'm going to ask around for original Detroit ones.
E60B950A-015F-49C5-9411-657D8265B92A.jpeg 4F20B7E9-0C93-4B31-B97B-11D5768E095E.jpeg
Finally. It’s astounding that manufacturers can’t measure or advertise correctly.
I’ll let you know about the NEAPCO 1-6300
If you find the correct ones, grab me a set too..I’d appreciate it
I'm going to send a note to Dr. Diff to see if he has heard any
thing.
I have an old original shaft from my 70 D200.
I'm going to measure everything before I take it apart.
I'm going to message all my buddies to dig up any original Detroit 7260s in their junkpiles.
Talked to Dr. Diff.
He said after installing the u joint, give the yoke ears a whack with a dead blow hammer (hard plastic) to seat and relax the u joint.
I'm going to AZone to pick up a couple of u joints and give it a whirl.
I think you’ll find that the grease boots hold the cups apart. Squeeze the joint together in a vice and measure. It’s not uncommon to see the shaft dimension close up some either. Dr Diffs method will usually spring them back. Much better caliper.
